Re: Another Coil Question
Posted by John T on July 31, 2008 at 09:25:42 from (66.244.97.31):
In Reply to: Re: Another Coil Question posted by SuperA-Tx on July 31, 2008 at 08:27:48:
NO, by elec switch I was referring to an electronic ignition switch used to replace a set of old fashioned contact points. As you say if it aint broke dont fix it and that 12 volt coil (if its indeed 3 ohms primary resistance) ought to be fine without any ballast.
best wishes
John T
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
