Anything is possible. Once we put a JD loader from a JD 310? backhoe on a JD 3020. Required substancial work on the mount (extended about 18" to rear axle) and had to cut the loader in half longways and make it wider.
For $400 in decent shape I would jump on it quickly before the word spreads. I paid $3700 (good deal) on a Koyker 220 for my F504D and still had to make my own hydraulics. But it was truly a "bolt-on" experience. Not one part was out of spec. Koyker has their stuff together.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
