Re: New governor assembly for Farmall B
Posted by Bob on August 01, 2008 at 10:59:24 from (69.178.228.68):
In Reply to: New governor assembly for Farmall B posted by Bill Carr on August 01, 2008 at 10:03:31:
When #1 cylinder is @ TDC, the mag drive slot must be HORIZONTAL.
That's all there's to it. ASSUMING the crankshaft-camshaft timing is correct, simply set the engine to #1 TDC, and install the governor so the drive slots winds up horizontal. Simple, eh?
