Posted by Bob on August 01, 2008 at 12:29:37 from (69.178.228.68):
In Reply to: Oooppppsss! posted by ScottyHOMEy on August 01, 2008 at 11:02:11:
Scotty,
As you know, with a distributor, position of the drive slot @ TDC really doesn't matter, as the distributor can be timed to compensate.
HOWEVER, with a mag, the drive slot needs to be darned close to horizontal @#1 TDC, or there won't be enough adjustment in the mag mounting slots to compensate. Probably better not be more than a tooth off either way of horizontal.
If you have a spare mag, you can see this for yourself. Clamp the bottom of the mag flange in a vise. Then, grab the drive tab with a ViseGrip, and slowly wind up the impulse spring, and note that the impulse trips when the drive tab is horizontal.
This is an almost universal situation, 'most ALL old engines have their mag drive slots horizontal @ #1 TDC.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
