Re: Farmall M electrical........
Posted by John T on August 01, 2008 at 13:18:25 from (66.244.97.31):
In Reply to: Farmall M electrical........ posted by Bill in IL on August 01, 2008 at 12:21:59:
On the hot ignition problem, Id suspect a coil or possibly a condensor, if hot wiring to by pass the ignition switch makes her run, suspect bad switch contacts. In the meantime tighten the belt and insure good grounds and wiring connections on the charging system. Heres the link to charging troubleshooting if needed..
John T
