Re: small hair line oil leakage
Posted by Randy-IA on August 01, 2008 at 13:44:25 from (207.177.83.243):
In Reply to: small hair line oil leakage posted by Brissco on July 31, 2008 at 18:34:43:
I had a small leak before my tranny broke last year right under the belt drive that I didn't think much of . When I got the cover off and steam cleaned it real good I found it was broken clean through in that area . Just a hairline break that someone had tried to braze but that didn't work . I tried JBweld and that didn't work either so I still have a small leak right there . Next step is to find a '47 vintage cover that's in good shape . Sorry I couldn't be of any help . Just remember that if oil can get out water can get in . Good luck . ...Randy
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
