You still have the old part? Can you find the mark on it? If so, you can skip all the other rituals and use the old one for a pattern to find where the mark should be on the new one. Ignore the orientation of the weights, they don't matter. Set the old and new next to each other with the magneto drive slots oriented the same. The new one should have the mark in the same position as it is on the old (or 180 degrees away!).
Since everyone is throwing in their comments on which way the mag drive slot should be oriented at TDC, I'll add mine. It should be at about the 2-8 o'clock position, 35 degrees above horizontal, viewed from the rear into the engine.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
