Re: 1486 Whats the chances?
Posted by IaGary on August 01, 2008 at 14:01:29 from (207.177.17.200):
In Reply to: 1486 Whats the chances? posted by TWL on August 01, 2008 at 12:42:05:
Yup I agree with Allan.
It would slip in the lower gears also if it was the TA.
Engine clutch slips in higher gears first. And soon it will be all gears.
Gary
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
