Re: Noise in Hydraulic IH 686
Posted by IaGary on August 01, 2008 at 15:18:48 from (207.177.17.200):
In Reply to: Noise in Hydraulic IH 686 posted by james Ashcraft on August 01, 2008 at 14:21:46:
I got a 1086 that I run over full for the same reason. Suction tube.
We will fix it the next time we got her opened up.
Gary
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
