Re: Noisy Rear End
Posted by Red Mist on August 01, 2008 at 18:12:06 from (72.171.0.148):
In Reply to: Noisy Rear End posted by Brian Jensen on August 01, 2008 at 11:15:41:
Brian Jensen said: (quoted from post at 11:15:41 08/01/08) Anyone have any ideas how to quiet a noisy (whiny) rear end? Can a guy use straight Lucas in it?
*Note - This is not for an IH it is for a Massey Harris. I have gotten lots of helpful advice off this forum for my 450d and the MF forum doesn't seem as active. I did not think the brand would matter on this subject, just the application.
Bananas, saw dust - old used car lot remedies. Yes, you can use straight Lucas. You can also use straight STP if you want. But, if it doesn't quiet down with regular 85w-140 gear lube, then you are just hiding symptoms. However, it is a "passive" problem - meaning it won't go away, but probably won't get any worse real fast either. In that case, ear plugs would work just as well as Lucas or STP. mike
