Check for a terminal lug in the ignition primary wiring which might be down to 1 or 2 strands of wire making contact. Pull firmly on suspected connections to locate problem areas. I believe that the coil is running on low voltage due to a high resistance, & turning the lights on drops the voltage enough more to lose spark.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
