Posted by Brissco on August 02, 2008 at 18:50:52 from (205.188.116.73):
I have a 53 SM in checking rear oil level I find it is Black and very thick, even a gelatin like texture. It seems that it may be the original oil, and needs to be changed. How should I go about this? Such as: Should I heat up by running tractor before draining? should the rear be rinced out with kerosine or deluted in anyway? Thanks
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
