Pipe threads seal by metal-to-metal tightness between the male and female threads. Antisieze is routinely used with new threads to lubricate the joint so that it can be tightened well. New threads shouldn't allow leakage if tightened sufficiently. We assembled high pressure (1500 psi) chemical plants with antisieze in all the pipe joints. If you had leakage (with no pressure), then your threads were damaged. Thread "sealant" does the same thing, and may help with old, reused threads, but it's the metal seal that makes pipe threads "work".
Today's Featured Article - New Hitches For Your Old Tractor - by Chris Pratt. For this article, we are going to make the irrational and unlikely assumption that you purchased an older tractor that is in tip top shape and needs no immediate repairs other than an oil change and a good bath. To the newcomer planning to restore the machine, this means you have everything you need for the moment (something to sit in the shop and just look at for awhile while you read the books). To the newcomer that wants to get out and use the machine for field work, you may have already hit a major roadblock. That is the dreaded "proprietary hitch". With the exception of the
... [Read Article]
Latest Ad:
[More Ads]
