You will need to split it. a days work to do a half-hour repair. You might want to think about replacing your throwout bearing as long as you've got it apart.
Splitting is more tedious than difficult, what with getting things like fuel line, governor linkage, hydraulics (if you have them), wiring and the like disconnected and back together.
The split itself isn't that bad but requires care in making sure everything is well supported. Cross-stacked wooden blocks are best. Jack stands extended to their full height are bad. If it's a wide-front tractor, you'll need to wedge the front wheels against the steering so that they won't turn. Maybe somebody will chime in with a good description (or pictures!) of how that's done.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
