Posted by Dan Bear Kelley on August 03, 2008 at 07:46:04 from (206.53.20.149):
In Reply to: Re: Steel hyd lines. posted by PaulW_NJ on August 03, 2008 at 04:56:44:
That is GORGEOUS work!
Other folk take note: Notice the two bends in the pipe. That is not only so it will get from point A to point B correctly, but it is also so that the pipes can have a little give in them for expansion and contraction.
SUPER work!
I'm a bit leery of doing the flares myself. I suppose if I got the tubing bent the way I wanted, a hydraulic shop could put the ends on it for me. I'm looking to interface a loader that was designed for a PTO pump to a full-time distributer mounted pump on my M (when I get that pump).
I am a bit leery about hoses, because they are a maintenance item. Yes, they will take vibration well, but they deteriorate from the inside out. So, you can never judge how good they are.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
