It is definitely a 6 volt battery. Vreg rft6a5 vroogr, starter delco remy 1109611 2m28. I just picked this lowboy up yesterday. I called and found out that it was running 2 months ago. When tried to start next wouldn't. A mech came, changed 3 plugs (couldn't get the 4th out) but would never start after that. The coil gets red hot. The negative on the battery is the grounded one and has been for 40 years they think. Claim did not remmove the battery when repairing. I get a hard kick in the starter and a stop, no turning over, I pulled the starter and it spins, I can not get the mower engage plunger to go to the rear and pop up, It is in the forward position (wold this affect starting?). can I check the coil? He said he used to pull start it by a truck, but when put in 3rd gear the tires lock up, the wheels will turn in 1st when pulled. I do ot have the crank bar to try to turn it from the front to check.
