Re: 62? Lowboy, w/bellymower
Posted by jrehm0001 on August 03, 2008 at 08:25:34 from (97.73.64.169):
In Reply to: 62? Lowboy, w/bellymower posted by jrehm0001 on August 02, 2008 at 14:41:57:
"Leaving the switch on when the engine isn't running will make it run hot."
What switch? on the face it hace a guage, a pull out to start and a dial type? He claims he doesn't know what this dial type thing is. Is this a on/off? which position should this be in. it has not markings.
The coil has the black wire to the distributor # 3898RI, and an orange one into the mesh harness. The starter has the large cable to the positive side of the battery and the other wire into the harness.
If this was running recently, should I still change the battery to positive ground? This means only one wire from the positve to the frame, and the starter cable to the negative post on the battery? thanx, joe
I know, darn newbies !!
