Re: THANK YOU: RE: Farmall M Carb
Posted by GordoSD on August 03, 2008 at 08:56:21 from (66.115.200.140):
In Reply to: THANK YOU: RE: Farmall M Carb posted by Dan Bear Kelley on August 03, 2008 at 07:37:37:
I have an old motor on a bench with an 8 inch wire brush on it. It"s a "softer" brush, you can actually get your finger in it without getting hurt. I use this on carb bodies after the soak.
A daisy BB is the same size as that ball you lost, if you don"t mind the copper color:)
Sounds like you did a nice job on the carb.
Gordo
