Re: u-joint replacement
Posted by nebraska kirk on August 03, 2008 at 11:03:00 from (98.16.171.154):
In Reply to: Re: u-joint replacement posted by Bob S. on August 02, 2008 at 17:26:24:
Yikes! How did they expect to steer the tractor! If the U-joint is not welded to the yokes, then is should be eaiser to remove than if it was welded to the yokes. If it was me, I would just torch the cross so that I ended up with the 4 pieces that are pressed into the yokes, then just knock the pieces out with a hammer and punch.
