Re: Finally used my tractor for something useful!
Posted by Janicholson on August 03, 2008 at 13:28:20 from (199.17.61.165):
In Reply to: Finally used my tractor for something useful! posted by Mike CA on August 03, 2008 at 12:52:30:
It is advisable to not do that (if the "TREE" is less than 2 inches OK, but all larger, tough trees will be a dangerous pull.
The bigger trees don't come out, the tractor digs in a bit, and the pinion in the differential climbs up the ring gear tipping the tractor over backward. In a Flash!!
You can use the tractor for an anchor and use a come along to do the actual pulling. There is real danger there. Jim
