Posted by wallacedw on August 03, 2008 at 14:39:05 from (24.225.15.92):
In Reply to: Rebuild or replace? posted by CNKS on August 03, 2008 at 14:24:52:
Maybe I just don't understand the system...
I did a pressure check and the pump is putting out 1000psi. The shop manual calls for a minimum of 900psi and maximum of 1500psi.
It does lift but not over a couple hundred pounds, not the 1200 that I need which I believe is well withing it's capability. If the load is too heavy it would lift the front of the tractor but it won't.
I don't understand the pressure relief system. How does it work? How do I test it? I can't wrap my head around what pressure it is relieving and when.. :?
I am trying to avoid changing the fluid until I have figured out what else has to be fixed while I have it out. Getting expensive. It uses a screen for a filter.... as long as it is lifting a little, wouldn't it be able to lift a lot?
This post was edited by wallacedw at 14:41:16 08/03/08.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
