Re: bush hog drive shaft
Posted by old on August 03, 2008 at 15:53:37 from (4.245.1.250):
In Reply to: bush hog drive shaft posted by Walnutguy on August 03, 2008 at 14:47:03:
Well if you are set up to weld its not a big job to build a shaft for that. I do them on and off all the time and most parts you need to do it can be found at a farm and home supply type of place
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
