Posted by JimB2 on August 03, 2008 at 17:25:09 from (99.241.179.24):
In Reply to: Re: 414 value question posted by poorfarmall1 on August 03, 2008 at 16:52:40:
Hi Poorfarmall, yes 3414 and 3444 were the industrial models, may have heady duty front axle, front mounted hydraulic pump and some additional hardware. Re Brakes, now it has been 40 years but here is the fix, remove the disk brake housing by removing the adjustment bolt from the brake pedal lever and the 4 bolts that hold the housing to the side of the differential. Inside you will find 2 disks and an expansion mechanism that has 3 rollers in between held together with 3 springs. The brakes work by the rollers running up the ramps in the expansion mechanism and pushing against the disk surface. First cleanup the rollers and ramps, do not apply any kind of grease that brake dust will stick to. Next examine the disks for wear, most likely they are just glazed and shiny. I would take a wire brush and buff them to remove the glaze. The other problem that happens is when the disks are replaced, the new disks will only make contact on the outer edge of the of the worn brake housing. Solution is to grind a 1/16" off all way around the outside of new disk so they will contact the worn surface of the housing. Someone must have invented a tool to turn the worn brake housing surfaces but I never had access to one.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
