Re: Farmall B. Driving timing gears on cam and dr...
Posted by teddy52food on August 03, 2008 at 20:11:20 from (209.237.111.169):
In Reply to: Farmall B. Driving timing gears on cam and dr... posted by Bill Carr on August 03, 2008 at 19:38:43:
There is a soft plug in the block behind the cam. If you try to drive the gear on and the cam moves far enough it will remove the plug and you will have an oil leak. Remove the cam & do it right.
