Re: Finally used my tractor for something useful!
Posted by charles todd on August 03, 2008 at 21:11:39 from (205.242.95.130):
In Reply to: Finally used my tractor for something useful! posted by Mike CA on August 03, 2008 at 12:52:30:
I grew farming using everything from a Ford 841 to a JD 8400 all with loaded tires. In the right conditions, anything is possible. Most of the time if pulling on a stationary object even if it weighs more than the tractor it will not flip using the stationary drawbar. Physics are on your side because the tires will slip first. Now if using a drawbar on the 3-point, that is risky because it changes the pulling angle of the tractor to above the centerline of the axles and increases the odds of a bad situation.
Moral, Good judgement, stationary drawbar, and a clevis you should be safe.
By the way, congrats on giving the H a taste of work. Before you know it your yard will be full of impliments!
Charles
