Re: bush hog drive shaft
Posted by charles todd on August 03, 2008 at 21:34:04 from (205.242.95.130):
In Reply to: bush hog drive shaft posted by Walnutguy on August 03, 2008 at 14:47:03:
Your milage may vary if the damage is severe. A driveshaft is a balanced system of parts. You might be able to weld and repair and keep it all in true geometry. Most people that build driveshafts have a lathe and can spin the driveshaft to check for balance and tune as required. Doing this on the shop floor might create a new problem when you hook it back up and it flies apart at 540 RPM.
Bite the bullet and get a NEW one from a tractor dealer or TSC. They range from $200 up for a 50+ HP rating. I bought a used JD 6' mower and it did not have a driveshaft. It cost me $230 through a machine shop that I know. I have complete peace of mind that it will not fail and cause me or the machine injury.
I am not saying that you are not competent to fabricate a replacement. I myself am a maintenance technician/welder by trade. But I value my health and well-being first.
Good luck,
Charles
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
