Re: Can the Cub run on diesel fuel?
Posted by Mike Farmer on August 04, 2008 at 04:12:05 from (86.31.84.127):
In Reply to: Can the Cub run on diesel fuel? posted by superpunchy on August 03, 2008 at 22:28:16:
The manifold won't make any difference because as far as I know all diesels require an injector system of some sort so the fuel doesn't pass through the manifold. MTF
