superpunchy, first off there is no such thing as an "all fuels adapter." There were "all fuel" versions of Farmall tractors, but there has NEVER been an "all fuel" Cub.
Cubs are gasoline only, period.
"All fuel" means the tractor will run on gasoline, distillate, or kerosene. Distillate fuel is no longer available. Kerosene did not work well in spark-ignition engines, very weak on power. Most of these tractors were simply run on gasoline once gasoline was no longer rationed.
Cubs are still gasoline only, period.
If you want a diesel, get a tractor with a diesel engine. There is nothing practical that you can do to a Cub to make it run on diesel. It will not work.
Spend a few minutes and look up diesel engines on wikipedia. Diesel fuel will not explode with a simple spark, will not mix with air through a carburetor. Diesel fuel needs to be sprayed directly into the cylinder in a fine mist, then squeezed under tons of pressure to make it explode.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
