Re: Wow! BE CAREFUL OUT THERE
Posted by HENRY E NC on August 04, 2008 at 08:18:16 from (216.119.6.213):
In Reply to: Re: Wow! BE CAREFUL OUT THERE posted by Jimmy King on August 03, 2008 at 14:14:01:
Exactly right. When towing a disc or any other implement I always use the swinging draw bar . It seems to stabilize the pulling power. NUff said Henry
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
