Re: Can the Cub run on diesel fuel?
Posted by Mike Farmer on August 04, 2008 at 11:51:12 from (86.31.84.127):
In Reply to: Can the Cub run on diesel fuel? posted by superpunchy on August 03, 2008 at 22:28:16:
It would be possible to make a diesel cub (I think the Fergusson T20 deisel was only a very low 9.5:1 ratio)but fairly impractical.I guess it would blast the engine apart in minutes. There are a few 75cu and up deisel engines on the market so a conversion would be possible but I guess totally pointless. Too much of a strain even thinking about it. MTF
