Re: Can the Cub run on diesel fuel?
Posted by Dellbertt on August 04, 2008 at 13:29:00 from (209.172.22.208):
In Reply to: Re: Can the Cub run on diesel fuel? posted by superpunchy on August 04, 2008 at 11:06:54:
Scotty, Don"t even listen to the negative slams.
Whatever your reasons, at least you are thinking and doing which is more than most.
