Re: IH 130 won't start
Posted by Andy Motteberg on August 04, 2008 at 15:23:14 from (4.143.219.200):
In Reply to: IH 130 won't start posted by Buggy on August 04, 2008 at 14:44:15:
Make sure that the fuel tank, sediment bowl and fuel line are clean. If you have a in-line fuel filter, get rid of it. You probably need to check the inside of your carburetor. Take it apart, spray all parts in carb cleaner several times, and use lots of compressed air to clean the inside/outside of the carburetor. Make sure the float level is correctly set and install a new carb kit, YT should have the kit you need, but make sure you get the right kit for your carb.
Good luck!
Andy.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
