Re: IH 130 won't start
Posted by Gene Bender on August 04, 2008 at 18:09:04 from (67.55.226.165):
In Reply to: IH 130 won't start posted by Buggy on August 04, 2008 at 14:44:15:
Get someone to help then try this. Remove #1 sparkplug put the wire on it and make sure it is grounded. Now have someone hit the starter with the sw on. With your thumb or finger in the sparkplug hole watch when the spark apears at the plug that should occur when you feel top of compression stroke with your finger in the hole. That will tell you if the rotor is lined up when it fires and your finger feels the push from the compression.You need someone to hit the starter button unless you clamp the sparkplug to the steering shaft. I do this as a quick check when someone tells me the engine wont start. If the plug fires when compression is there it has to be a gas problem.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
