Re: farmall M has no spark
Posted by Wayne in MN on August 05, 2008 at 06:06:07 from (68.119.27.241):
In Reply to: farmall M has no spark posted by guntrk6 on August 05, 2008 at 05:18:04:
Look in the distributor where the primary voltage (12 V.) wires are connected; you may have accidentally grounded the wire inside.
Disconnect the wire on the outside of the distributor and check for voltage. Hold the points open & re-attach the wire; if there is a spark at that terminal, the inner connection is grounded.
