Re: Farmall C starter flywheel replacement
Posted by M. Doud on August 05, 2008 at 09:16:48 from (207.68.116.74):
In Reply to: Farmall C starter flywheel replacement posted by lpaul on August 03, 2008 at 06:49:17:
After you get it apart you can probably just flip the gear and put it back on. Mine was only worn on one side.
Make sure you heat it before you try to drive it off, otherwise you"ll break the lip off of the flywheel.
DAMHIKT!!
Mark D.
