Re: Temp gauge on 42 B Farmall
Posted by Bob on August 05, 2008 at 11:41:06 from (69.178.228.68):
In Reply to: Re: Temp gauge on 42 B Farmall posted by Bob on August 05, 2008 at 11:14:16:
The little mounting plate is Item #11. It bolts to 2 of the governor bolts.
11 50495D HEAT INDICATOR BRACKET #501 to #11091
11 53620D BRACKET/Retired HEAT INDICATOR BRACKET #11092 up
#13 is the water elbow, tapped for the heat gauge bulb.
13 6764DAX ELBOW/Retired WATER INLET ELBOW WITH PLUG, 103869 (will work for 6501DA)
