Tim - If you look on the underside of the bolster casting you've find a crescent-shaped slot cast into it. A special extended head on one of the 4 bolts that attach under lower bolster flange to the pivot shaft flange fits into the crescent. (If memory serves it's the right front corner...) The extended head on bolt in this slot limits pivot shaft rotation to a bit under 90 deg left and right of center.
My bet is a regular bolt has been used to replace the special extended head bolt in this position.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
