Re: engine for a Farmall B
Posted by ScottyHOMEy on August 06, 2008 at 06:59:13 from (70.105.231.176):
In Reply to: engine for a Farmall B posted by Frank C on August 05, 2008 at 18:51:29:
Should fit, but if you use a SuperC motor, save the cooling outlet that runs from the head to the radiator from your. The dimensions are different for the taller radiator of the SuperC. You might also have to find or fab up a cover to replace the hydraulic pump, unless you can rig up something so that you can make use of it.
