Re: Outer Bearings
Posted by No tools on August 06, 2008 at 21:38:00 from (71.79.47.23):
In Reply to: Outer Bearings posted by HFarmall on August 06, 2008 at 19:16:01:
No you do not have to remove top cover.Drain part or all the oil. Remove PTO.That will access you to retaining bolt in end of axle.Remove bolt /Then 4 bolts on end of axle housing (out bearing/oil seal retainer) pull the whole axle out if you wish.Usually you don't have to.
Also get the inner same as above just lay/tilt bull gear over out of way.
