Re: Super A Battery Box
Posted by ScottyHOMEy on August 07, 2008 at 11:28:38 from (70.105.231.176):
In Reply to: Super A Battery Box posted by mkirsch on August 07, 2008 at 11:09:02:
Wonderin' if the height of the battery isn't at the root of your problem. My SuperC has the two-sided battery box, but I'm not sure what you're boltin' to on the SA. OEM lists those side panels as fittin' both the SA and the SC.
Where does the ground wire from the battery attach? On the SC, it grounds through the right rear upper bolt holding the battery box, so it has to be lower than, or at least just above, the top of the battery to be able to make that connection. I have no problem snakin the battery in thorugh the Touch Control rods to get it in place, but that ground cable is so short as to be almost rigid, and is the biggest pain in the neck.
I'll go out and look on some battery sites and see if maybe there's two different Group (i.e., case size) numbers for the 6v and let you know what I find.
