Re: Farmall M Stroker Crank
Posted by TC2 on August 07, 2008 at 11:52:10 from (132.79.8.15):
In Reply to: Re: Farmall M Stroker Crank posted by TC2 on August 07, 2008 at 11:50:52:
Just to add more info, the part number on the crank is 45571 DC. I don't find this one listed in the parts catalog, but found one site that says it is a 400 crank. The one the parts book shows for a 400 is not DC though. Any help?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
