If the PTO shaft stops turning on its own in just a couple of secondsafter pushing the clutch pedal and before you put the tractor in gear, your pilot bushing is probably fine, and the noise you have is just the nature of the beast. I call it the Farmall grind. Straight cut gears are a little clashy going in anyway, and you have to give the shaft a couple of seconds to stop. And they might still clash if the gears stop with two teeth facing each other, which only means that you have to ease the clutch in a little to spin them enough for a tooth to find a notch it can mesh into, which will make more of a belching crunch than a rattling clatter.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
