Re: farmall super c clutch problems
Posted by Randy in NE on August 07, 2008 at 13:04:53 from (204.124.192.31):
In Reply to: farmall super c clutch problems posted by codync on August 07, 2008 at 11:46:13:
Scotty gave you a pretty good overview. On the C's and Super C's if you move the gear shift lever to the right and then forward (there is no gear there) it acts a transmission brake and it will stop the gears a lot faster than friction through the transmission grease. Are you getting the clutch stepped all of the way? When you have it in gear and start letting the clutch out, how far does the clutch pedal move before the clutch engages? If it doesn't move very far then it is definitely out of adjustment. Follow Scotty's instructions on adjusting it.
