Posted by chip armstrong on August 07, 2008 at 15:52:35 from (71.56.190.148):
In Reply to: 140 pto posted by chip armstrong on August 06, 2008 at 03:22:11:
Got the pto off and apart, no problem. Any trick to getting the small gear off the top shaft without breaking something? My 20-ton press and heat didn't seem to impress it at all. Got it soaking in pb blaster right now. Also, how to get shaft and gear out of pulley drive housing-got outer bearing off. (ordered shop manual from IH dealer, got owner's manual instead. Oh well)
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
