Re: Fast Hitch Plowing
Posted by D Slater on August 07, 2008 at 16:06:00 from (71.164.43.57):
In Reply to: Re: Fast Hitch Plowing posted by RAW in IA on August 07, 2008 at 15:29:01:
If I remember correct your right leave the bell crank pin out and sway limiter free, pin in left lift link, level crank collar in top set hole and two point socket pins out of the lock holes.
If you have the lift cylinder like a 450 with cylinder stop rod, set the rod to limit plow depth. If uneven ground or crossing field ditches that doesn't work the best though. Soil type I plowed with traction control hitch would work good enough to cause front wheels to float off ground if set to full or next to full in some places.
