Re: All Electrical Gurus Farmall 130
Posted by GA Dave on August 07, 2008 at 18:44:05 from (207.69.140.32):
In Reply to: All Electrical Gurus Farmall 130 posted by Hugh MacKay on August 07, 2008 at 17:40:44:
Hugh MacKay said: (quoted from post at 17:40:44 08/07/08) Bob: I just went out and checked voltage with tractor not running, and it's close to 13 volts. The tractor hasn't run more than 35 minutes total since I installed the new battery, and in that time probably a dozen starts. I'd like to sort this out before I start to work it.
35 minutes run time and a dozen starts! That averages less than three minutes charge per start. That could be the reason for the 10 amp reading. Is the battery losing fluid? If not let it run but keep an eye on things. David.........
