I doubt you damaged anything! Your voltage readings are right where they should be. The issue instead is you're not running the tractor enough to fully recharge the battery as David (below) points out.
Also....there's a very good chance the new battery was partially discharged when you installed it. Your subsequent brief run times have not been enough to bring it to a full charge. Thus the constant 10 amp reading on the ammeter as the alternator works to recharge it to 100%.
If it concerns you, suggest sticking a charger on on overnight to fill up the battery. I'll bet then the ammeter will return to running near center.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
