Posted by kpandrews on August 07, 2008 at 20:41:48 from (72.69.187.94):
I have a 1944 Farmall-A with a pneumatic lift set up on the left side of the tractor to lift an implement attachment on the rear of the tractor.
Can this lift be rebuilt to be able to lift and hold a 3-point mounted brush hog? Is the lift supposed to hole position even when the exhaust is routed to exit the muffler?
My A does not have a muffler. Is there any issue with using a muffler if the tractor has a pneumatic lift.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
