Re: Update on Hydraulic noise on 686
Posted by Jim J on August 07, 2008 at 21:12:03 from (76.4.172.202):
In Reply to: Update on Hydraulic noise on 686 posted by james Ashcraft on August 07, 2008 at 14:46:20:
The piggyback pump supplies the 3pt. The fix that I have found for getting the captive air out of the hydraulic system is to take the return line that goes into the suction tube apart and cap the end that goes to the suction tube and leave the other end open. This will let the air that is captive in the system return to reservoir and not be feed in the suction line. I recommend that you put at least 2-1/2 gallons extra oil in.
