Re: dozer guy
Posted by DOZER GUY on August 07, 2008 at 22:13:24 from (75.106.35.64):
In Reply to: dozer guy posted by arkie on August 07, 2008 at 17:40:45:
Hi ARKIE, It sounds as if the nozzles are not tight. Did you put new washers in the head before installing the nozzles? make sure that the nozzle holes are pointing down towards the pistons. e-mail is welcome.
